I am using Kicad 7.0.6 and need to copy all the testpoints in my layout to another PCB to create a testbench.
Earlier with Kicad 6 this was simple, my Testpoints all have a circle in user layer 1 so I just deactivated all layers but userlayer1 and pressed ctrl+A, then all the testpoints were selected and I could copy them. With Kicad7, pressing ctrl+A does not select anything as long as the copper layer is not visible… I don’t fully understand what changed here, as I can not select anything on userlayer1 anymore.
however, is ther a quick way of selecting all the testpoints at once with Kicad7.0.6?
thanks!
Note the Hit(s): 3/6 at the bottom of the dialog. It has currently the third of the 6 found testpoints selected.
This (new?) feature may be worth a feature request at gitlab.
As a workaround you can make a copy of the PCB (or backup, or exit without saving, etc) and then just delete everything that you do not want. But it is a quite kludgy workaround.
Interactive HTML Bom has functions to for example “highlight all 100nF capacitors”, and it’s meant as a PCB assembly helper program. It probably can’t export a part to KiCad or anything like that.
thanks for your reply. yeah, the manual option of course is possible, but it takes long (we sometimes have hundrets of testpoints) and sometimes you make mistakes.
the “select all” button would be awesome. Not sure how to make feature requests, and it also will take long for implementing I guess… do you thing there would be an easy snippet for the python terminal to select all testpoints?
