Currently, you can select a track by clicking on one of its segments, and use the “U” shortcut (or use the Select / Single Track contextual menu item). But it selects the entire track, by following the vias, and includes the segments which are not on the current layer.
Is there a way to select only the segments of the track on the current layer until a pad or a via is reached ? It would be useful to be able to delete these segments on one go, and re-route them, instead of deleting them one by one.
Application: kicad
Version: (5.1.0-rc2-39-gd2d210117), release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Platform: Windows 7 (build 7601, Service Pack 1), 32 bit, Little endian, wxMSW
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 7.3.0 with C++ ABI 1011
You may have your hotkeys configured differently but, by default, ‘U’ selects only the single track on the current layer without T-junctions and not passing pads. ‘I’ selects the whole connected track.
edit: Corrected graph above as noted by @pedro. Thanks! Note that this makes the answer to @Efcis not on point, so the bug listed below will be a wishlist item.
Oi! You are right that I was incorrect here. It will select up to a branch but a single track passing through a via will be selected as you correctly point out.
If you draw an alternative path for a section then the old redundant section gets automatically removed, and even if it does not, then the “u” shortcut only selects copper untill the first pad or T-junction.
If thad does not work, or is not to your liking, you can first delete a single strategic track segment or via, and then use select + u in a secondary operation.
You should also experiment with the global board cleanup:
