Selected Component in eeschema Is not Highlighted
Starting with 5.1.1, I observed that when I select, even double click on, a component in eeschema, it is not highlighted. However, the corresponding package in pcbnew is highlighted. If I select a package in pcbnew, the corresponding component in eeschema is also highlighted. So, it seems to me that highlighting in eeschema works but somehow is not activated when a component there is selected. The bug persists in 5.1.2. Here are the details of my installation:
Application: kicad
Version: 5.1.2-f72e74a~84~ubuntu16.04.1, release build
wxWidgets 3.0.2
libcurl/7.47.0 OpenSSL/1.0.2g zlib/1.2.8 libidn/1.32 librtmp/2.3
Platform: Linux 4.15.0-47-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.2 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.58.0
Curl: 7.47.0
Compiler: GCC 5.4.0 with C++ ABI 1009
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
In my experience symbols have never been highlighted when clicked on in eeschema. Actually symbols or other items can’t be selected at all in eeschema by clicking on them. The behavior is annoying and inconsistent between application and I hope it will be changed before 6.0.
We are planning on updating Eeschema to use the selection model from PcbNew as part of the 6.0 effort.
Thank you very much. I thought it might be possible.
As of version 5.1.1 the only case of highlighting seems to be on selection of a component in Pcbnew and then switch to Eeschema. The component will be highlighted reddish in Eeschema.
