Hi everybody!
I locked some vias in my pcb but I need change and move it. I tried to select it again (like I do with locked footprints and nets ) but it’s impossible! I can’t select a locked vias and I can’t move it!
How it’s possible? Someone has some tips? Vias has no reference so it’s impossible to select using "Find " function.
In the image you can see the locked vias, a blue ring is around them.
Thanks a lot for your help.
If you are able to select locked footprints than in Selection Filter you have to have Locked items checkbox checked.
When I have this checkbox checked I can select locked vias.
May be you have unchecked Vias checkbox there.
I don’t understand the question.
May be you don’t see it because of screen resolution?
I’ve never tried KiCad at smaller resolution than 1920x1200.
If it is a problem… I think it is acceptable that such program as KiCad can need some minimal resolution but if someone has less he should be warn about problems.
If KiCad silently just not show Selection Filter than I think it is a bug worth reporting.
By the way.
When I was designing my first PC designed PCB I was using CGA (resolution 320x200) and B&W 14" monitor (green display). I mixed RGB lines with resistors to get different gray levels for different colors.
And that PC had no HDD
