after upgrading from ubuntu 14.04 to ubuntu 16.04, I am not been able to run kicad anymore
When I start kicad from command line I gain a “Segmentation Fault” error.
So, I tried to uninstall kicad, wxwidgets, I remove and reinserted the repository, reinstalled but no way, It does
not work.
I installed from:
add-apt-repository ppa:js-reynaud/kicad-4
I tried to solve the segmentation fault by inspecting the core file. Seems to be a problem in wxThings, as reported below:
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00007f9d0c78241c in std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >::_M_erase(unsigned long, unsigned long) () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
(gdb) where
#1 0x00007f9d0caa7799 in std::__cxx11::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >::erase (
__n=18446744073709551615, __pos=0, this=0x6d9258) at /usr/include/c++/5/bits/basic_string.h:1460
#2 wxString::erase (n=18446744073709551615, pos=0, this=0x6d9258) at ../include/wx/string.h:2846
#3 wxString::clear (this=0x6d9258) at ../include/wx/string.h:2867
#4 wxFileName::Clear (this=0x6d91d8) at ../src/common/filename.cpp:602
#5 0x000000000045c274 in ?? ()
#6 0x000000000045a8a4 in ?? ()
#7 0x00000000004217cf in ?? ()
#8 0x000000000048538d in ?? ()
#9 0x00007f9d0bb6a7bf in __libc_start_main (main=0x421700, argc=1, argv=0x7ffdc7e17bb8, init=0x485340, fini=<optimized out>,
rtld_fini=<optimized out>, stack_end=0x7ffdc7e17ba8) at ../csu/libc-start.c:247
#10 0x0000000000425d87 in ?? ()
I miss KIcad could you please help??
Thanks in advance for your time and consideration.
-g
http://ppa.launchpad.net/js-reynaud/kicad-4/ubuntu is my ppa. I am also on ubuntu 16.04. Kicad version
Application: kicad
Version: 4.0.4+e1-6308~48~ubuntu16.04.1-stable release build
wxWidgets: Version 3.0.2 (debug,wchar_t,compiler with C++ ABI 1009,GCC 5.4.0,wx containers,compatible with 2.8)
Platform: Linux 4.4.0-36-generic x86_64, 64 bit, Little endian, wxGTK
Boost version: 1.58.0
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
USE_FP_LIB_TABLE=HARD_CODED_ON
BUILD_GITHUB_PLUGIN=ON
Works without issues, checkout whether the URL is correct which has extra ubuntu at the end compared to what you have typed
