You sir, are correct. My amazon order was a 10 pack of 28-pin dip sockets, an assortment of colored 5mm LEDs, a pack of right angle pin headers, and an assortment of proto boards. The dip sockets are scrap. One had a mangled connector and the one I used, one of pins wanted to push up and out of the plastic socket as I inserted into the pcb. Haven’t looked at the LEDs or the headers. The proto boards are double sided PTH boards and are of good quality. Yes, it is a YMMV case with amazon & ebay.
The next part of the project is building a USB interface board for my home made arduino, so I can program directly from my pc, without using another arduino. Here’s my schematic:
and my PCB:
It’s all SMD because I have to learn to work with it. I have no experience with this stuff, so I choose larger footprint components. All parts for this was ordered from digikey.
I’ve been reading this thread:
https://forum.kicad.info/t/smd-assembly-hot-air-plate-or-oven/30716/16
I don’t have a hot air set up for this type of work, or an oven to use for this type of work. But I do have a clothes iron from another hobby, and a saute pan with sand is easy to do also…
Will update when I get results.
I’m open to any suggestions,
Randy
