Recently I was manufacturing some boards with Seeed Studio’s FusionPCB service, and that has a specific (albeit simple) BOM template requirement, something like:
Part/Designator,Manufacturer Part Number/Seeed SKU,Quantity
C1,RHA,1
"D1,D2",CC0603KRX7R9BB102,2
I haven’t seen any plugin that generates this format by default, and I wanted to play with / contribute to KiCad a bit, I’ve put together a simple plugin. Seeed released their Open Parts Library (OPL) for KiCad too, relatively recently, and thought to take advantage of that as well. Thus came up with the convention:
- OPL parts have a
SKU
value defined, that’s the default value to export - If there’s no
SKU
, then aMPN
field is searched and exported - If neither is found for a part, nothing is exported for that, and at the end of the export a warning is issued.
Thus for every part either set a SKU with the OPL part number or an MPN value.
You can find the plugin on Github at:
Just clone it somewhere on your hard drive, and add it in eeschema
with a name. It works with both Python 2 and 3, and should only use standard libraries:
Any feedback is appreciated as well!
