Hello, I am looking for the configuration file in which the Windows KiCad Environment Variables are stored!
My search pointed to a file:%AppData%\kicad\6.0\kicad_common.json
Unfortunately, the list of variables is incomplete.
Probably because some of them have a special meaning because they are used in the official libraries and internally, and they have internal default values. The defaults aren’t saved. If you change them they will be saved.
I don’t understand how to use eg. c# can determine the location of: ${KICAD6_3DMODEL_DIR}/TestPoint.3dshapes/TestPoint_Bridge_Pitch3.81mm_Drill1.3mm.wrl.
${KICAD6_3DMODEL_DIR} so there must be a reference to the folder stored somewhere.
It’s not stored anywhere, it’s virtual
Thank you for your answer, even if I can’t get any further with it.
