I have a schematic design with one root-sheet and 7 subsheets (the flat-design-principle).
I have used only global labels.
The schematic is nearly done, I’m on revisiting and checking.
What’s the best/easiest way to search/highlight nets across multiple sheets?
Actual I use the search function, but this is not really satisfying. My complaints are:
- I have no overview of all found places of the search (missing feature)
- CTRL+F search-dialog positions itself onto middle of the screen, the schematic sheet zoooms and centers the found search-result also to the middle of the screen -> the search-result is hidden under the search window (bad user-experience)
- If I push the search-window to the side/top/bottom so that it doesn’t sit above the centered search-result, it’s better. But Kicad forget’s this position and puts the search window again at the middle of the screen at the next search (bad user-experience)
- Hotkey F3 (find next) opens again the search window and doesn’t directly search and show the next match (maybe a bug at the hotkey-assignement?)
- sometimes the search-function stops at the end of the actual schematic and doesn’t search all the following schematic-sheets (maybe a bug - until now not always reproducable )
- If I have a search with many results (+3.3V for instance) and I want to go one match back in the search-result-list this is not possible. I have to click many many times to go through the complete result-list until it begins from start. Either a result-list (see point1) or a “find last match”-hotkey could help in this situation (missing feature)
- If the search finds the next occurance at another sheet Kicad opens this schematic-sheet. That’s good, but it doesn’t refresh schematic-navigator-panel (where the actual showed page should have a gray background). Thats irritating. (maybe not implemented until now, maybe bug)
- If using the search-function with an selected object it would be nice if the object-name/text is automaticly placed in tthe search-edit-field. (wish)
Questions:
- Are there other ways/tools to help me get an overview about the usage of all my global nets/power ports?
- I would like to write some of the points to the kicad-gitlab-bugtracker-list. OTOH I don’t want to spam the list. Should I make one big or better many small reports?
Maik Freitag
forgot: Kicad v5.99
