You posted it in the footprint section, so you probably have read:
How hard can it be to find a datasheet for that common connector?
Did you try websites of manufacturers?
Did you try the big stores (Digikey / Mouser / Farnell / Element 14 / LCSC / Etc.?
On top of that.
There are usually many different footprints for the same type of connector. The “connecting” side is standardized, but the way it is mounted to the PCB is not. And therefore you really need the footprint that fits your exact connector, so you have to buy them from a good source, that also delivers the datasheet for the connector, or you have to buy a bunch of those connectors, measure it and reverse engineer a fitting footprint yourself.
