Screw terminals and terminal block
Hi, I have a 1x2 and 1x4 screw terminal block on my design. I find this under terminal block;
terminal block bornier 2_p5.08mm
terminal block bornier3_p5.08mm
terminal block bornier4_p5.08mm
terminal block bornier5_5.08mm
terminal block bornier6_5.08mm
5.08mm is the pin spacing for a 1x2 screw terminal. Does anybody know the meaning of the numbers 2-6? Thanks.
Look at the footprint and it will be obvious it’s the number of pins.
general advice for the original kicad libraries: these follow the KLC (Kicad Library Convention) .
The KLC can be found: https://klc.kicad.org/
The naming-scheme is described in chapter F2.1.
This includes a explanation for connector-naming as well as for passives (resistor/capacitor) and for the many numbers in footprint-names for integrated chips.
