Royce
January 12, 2022, 3:35pm
1
Hi folks,
I know it’s a little OCD but still…
I imported a schematic symbol from SnapEDA and noticed that the background color is white:
All the other symbols have the classic yellow’ish background color:
Is there a way to change the background color form the first symbol from white to the “standard”?
Thanks in advance!
Save it to a personal library and then edit the outer rectangle. If you right click on the rectangle you can adjust the properties to ‘Fill with body background colour’. Save your modified symbol.
Royce
January 12, 2022, 3:44pm
3
Thanks you.
That’s exactly what I tried but the background color stays white.
I guess I’ll just draw it new real quick
Can you post it here? It is possible that the symbol is malformed in some way and might be worth letting SnapEDA know if there is an issue.
Royce
January 12, 2022, 3:47pm
5
Of course, I’ll upload it with this post
SS495A.lib (611 Bytes)
Its been made with four lines around the edge not a polygon. Just replace the lines with a polygon and it should allow you to fill it.
Royce
January 12, 2022, 3:50pm
7
Ah that makes sense. Thank you, John!
Whilst you are at it, you might also like to edit the pin types - they are all set to bidirectional but VCC & GND should be power in if you want ERC to work.
Royce
January 12, 2022, 3:59pm
9
I already changed that but thanks for noticing
paulvdh
January 14, 2022, 2:10am
10
@C.M.Bracho (From Snapeda) You may want to look into this, to generate polygons instead of lines for higher quality symbols.
Thanks paulvdh for reaching out. It seems this symbol was uploaded by one of our users, and we’re going to check on it.
Also, we’re going to inform about this process to our team, we really do appreciate your feedback, guys!
system
Closed
April 14, 2022, 5:42pm
12
