When drawing a schematic I generally need to reposition some of the components at some point. The connections are preserved if I use ‘g’ to grab and drag components, however the connections are at odd angles rather than horizontal/vertical. Is there any way to move components and for the connections to keep to the horizontals and verticals
You can use block select to move a larger part of the schematic at once.
This preserves the angles within the moved block.
Moving single part with preserved angles would require an autorouter. This is understandably not implemented.
