Harjit
November 21, 2023, 7:01am
1
In the schematic, I dispositioned some ERC with an exclusion. The next time I run schematic and do an ERC check, my previous dispositions are lost.
There is an issue in GitLab but it is closed: https://gitlab.com/kicad/code/kicad/-/issues/6425 .
Has the feature been implemented and I’m not doing the right thing or do I reopen it or?
Thank you.
Are you opening the project via the project file or from standalone eeschema? The exclusions are stored in the project file.
paulvdh
November 21, 2023, 8:09am
3
If you look at the date of that gitlab issue, you see was closed over three years ago.
It also has a direct link to the changes made, and from there you can follow the whole thing through git if you know how that works.
Jeff Young closed via commit 826e47dd Nov 19, 2020, 7:34 PM
So you are either running a more then 3 year old KiCad, making some mistake as retiredfeline suggests, or found a new / unrelated bug.
Harjit
December 25, 2023, 4:19pm
4
Thank you for the info. and confirming that it does work.
I just tried it again and indeed the ERC dispositions I did last time were still there. I don’t know why they disappeared from the time before.
system
Closed
March 24, 2024, 4:20pm
5
