Windows 10 x64, V8.0.7
Preferences - Schematic - Colors - Symbol body fills : Ignores any changed color when clicking ‘OK’. Might this be a Windows-only problem ?
kicad
help >> about >> copy version info (to clipboard)
Paste that here.
Sorry about the delay to reply:
Application: KiCad x64 on x64
Version: 8.0.7, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.0.1
FontConfig 2.15.0
libcurl/8.10.1-DEV Schannel zlib/1.3.1
Thanks
Are you using your own color theme, or trying to change a “Read only” theme?
Can you change the colors of other items?
No, I’m just trying to change the symbol fill color.
What about this question?
And also this question?
Not using a color theme other than the default.
Which default? It’s still not clear if you’ve selected the editable theme, or have the default read-only one:
Here is your problem:
Kicad default color schemes are “read only”.
You must have a personal color scheme to be able to change any colors in Kicad.
To create a personal color scheme: Preferences > Schematic editor > Colors then click on the triangle at the RHS of the “Theme box” (where red arrow is pointing above). Select “New theme”, type in a name, OK. The new themw is exactly the same as the kicad theme originally showing, but now it is also yours and can now be modified.
Thanks. This didn’t seem obvious.
And at least update to 8.0.9, which fixes some bugs since your 8.0.7
