Schematic Hierarchy : Quality of Life Questions
Issue
Regarding the Schematic Hierarchy, is there a means to:
  1. (Auto)sort alphabetically
  2. Refresh page numbering, counting from the Schematic Hierarchy top to bottom
    • indiscriminately, or
    • hierarchally (not dropping to the next lower sublevel until all of the present sublevel has been numbered).
  3. Collapse / Expand All (recursively - to all sublevels)
    • This is especially important because they an Expand All occurs with every annotate.
Example
I made an example with an array of [8x4] 7-segment digits, (depicted below).
Note that:
  1. Under Digits, Digit_1.2 precedes Digit_1.1
    • Also, the subschematics under Digit_1.2 and Digit_1.1 are in different orders,
      (despite Digit_1.2 and Digit_1.1 being hierarchal schematics with identical contents).
  2. Under Digit_1.2, RGB LED_r1 is page 10 but it’s successor RGB LED_bot is page 21.
  3. The only means to collapse Digit_1.2 through Digit_8.4 is manually.
Suggested Resolution
  1. Sort contents alphabetically (local to hierarchy level)
    • Automatically, or by
    • Right-click → [ Sort contents ]
  2. Right-click → [ Update Page Numbering ] → Choose to sort by:
    • Indiscriminately (top to bottom)
    • Hierarchally (not dropping to the next lower sublevel until all of the present sublevel has been numbered)
      • Without remaining within the present parent.
      • Remaining within the present parent.
  3. Right-click →
    • [ Collapse / Expand All ] for one level of subcontents.
    • [ Collapse / Expand All Recursively] for all levels of subcontents.
Submitted here.
