Schematic Drawing Image resizing automagically
I"m working with a schematic in Kicad 8 which has a drawing sheet assigned. The current drawing sheet was created in Kicad 6. When I first open the schematic file the image is the correct size. When I go into the page settings, the preview image shows the image from the drawing sheet as a larger image. After clicking ok, the image resized itself to match what was in the preview. This behavior persisted until I restarted the project. I have not been able to replicate this bug.
I then created a copy of the drawing sheet and updated it with the Kicad 8 Drawing Sheet Editor. I have sized the image such that it is contained within the title block (800 DPI).
When I save the file in the Drawing Sheet Editor, it appears as expected. However when I open this drawing sheet in the schematic error, the oversized logo appears (approx 550 DPI). This does not correct itself by restarting Kicad. If I make the logo smaller in the Drawing Sheet editor (1000 DPI), the logo in the schematic still remains the same size.
Screenshot 2024-05-14 102125
Is this a known bug or is there a setting I’m missing that is causing this behavior?
Thanks in advance!
Application: KiCad x64 on x64
Version: 8.0.2, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Apr 27 2024 23:05:17
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.5.0-DEV
ngspice: 42
bumping to see if anyone can help
In KiCad, click Help->Report a bug
Attach the project with your drawingsheet to the bug report
