Saving to libs in library editor
IN version 5 there is reduced functionality in the library editor.
In version 4 you could select a component in the schematic. select to edit it in the symbol editor modify it and then save it to your own read/write lib .
Now there seems to be no way to change the lib selected, so if it comes from a read only lib like most of them , you are stuck. is it possible to change a library to mylib to save a modified symbol ?
Use the left mouse button context menu on the library list.
Thanks i think i have it now
  1. open symbol in symbol editor.
  2. use right hand mouse button to copy from hi-lighted lib.
  3. copy to own lib using paste.
  4. make changes.
  5. save own lib.
  6. exit symbol library editor.
