Edit: I manually set file properties in windows explorer, so I’m all set. Double click launches KiCad 9 as it should. As this is a Windows file descriptor, so it applies across file system AFAIK. IMO the file descriptor should not show version since it’s only based on file extension, no version info is determined.
I still think perhaps the installer should set these file properties? I took the recommended options in the installer, if that matters.
Running v9.0.2 release on Windows 11. When I save a project, and view the files in Windows File Explorer, the file type column in Details views shows:
“KiCad Project 8.0”
“KiCad Schematic 7.0”
“KiCad Board 8.0”
I know that I am running v9.0.2. And if I tried to open the project in v8 I would get the error that the project was created in a later version of KCad.
I used the KiCad 9 installer from the downloads page. I think that Windows 11 file type descriptor did not get updated? Is that a bug in the installer? Can I manually edit the file type descriptors? Or just not worry about it?
