I wonder if this is a Windows 10 or a KiCad feature, but at least “Save as” and “Print” dialogs give an empty file name for the new name. Project or Schematic file name are usually better
In both the Schematic Editor and PCB editor (I’m still on ver 6.x!!!) there is no “save as” option, there’s a “save copy as” (or similar), and that suggests the current name.
Not seeing any filename prompt for the Print function… (unless I use the windows “print to PDF” option, but that’s Windows, not KiCad!)
Can you therefore tell us which KiCad version / OS you are on, and where specifically you see this behaviour? (Help / About, then “copy version info”)
You quessed correctly, one problem was while making a pdf.
Sorry about about missing info. Here it is
Application: KiCad x64 on x64
Version: 8.0.1, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Platform: Windows 10 (käännös 19045), 64-bittinen versio, 64 bit, Little endian, wxMSW
Date: Mar 15 2024 01:52:47
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.5.0-DEV
ngspice: 42
