I’d like to use a 7400 series component that has invisible pins (Vcc and Gnd) in my design. However, I’d also like to use another instance of the same component connected to a different power rail (in my case Vif). Is it possible to this? Is so, how, and how do I make the difference visible in the schematic view?
See other threads.
Enable Show invisible pins, and connect to the somewhat hidden tie points, on those you want to over-rule.
Outcome: Any connected net, replaces the default Vcc,Gnd
