I have 4.0.7 installed and working well. I’d like to install 5rc2 as well, but without nuking 4.0.7
I downloaded kicad-r10378.6a2dc8d4e-x86_64.exe but when I run it, it says “KiCad is already installed. Installing this package will overwrite existing files.” ok/cancel. There doesn’t seem to be a way to point it at another directory.
Is there a way to make two version coexist on the same install? I guess I can always install 5 in a linux VM, but that’s annoying.
Hmm, how’s that possible? It’s not many weeks (or at least months) ago when I installed both on Windows, although it was x86 only. Either you didn’t look carefully enough into the installer or it has changed. I can take a look at it again later if the answer isn’t found.
