HI, I HAVE CREATED AN ANTTENA WITH FOOTPRINT EDITOR.
NOW,I CAN’T CONNECT THE 2 TRACES(LOOK AT THE PICTURE)
IS THERE A WAY TO CREATE TRACE REGARRDING OF THE NET LIST AND THE DRC?
DAVID.
DAVID.
You should use a net-tie for the connection
Better define the antenna-footprint correctly (keyword net-tie as written above).
Is there a way to create trace regarding of the netlist and the drc?
yes, if you want to go that way.
hi, it works.thanks alot!!
Glad to see your caps lock key has also been fixed.
yessssssssssssssssssssss~
