Hi there,
I got a problem in multi-layer routing.
here’s my routine for multilayer routing:
route a track, click somewhere to fix the track as I want.
when I have to change the track’s layer to continue routing,I press ‘v’.
the mouse cursor turns into via. I press the mouse button to place a via,
and then router’s layer has changed to another layer.
and here’s a question: to continue routing, I have to move the via
from where I lastely clicked to fix the track.
otherwise, routing mode ends as soon as via is placed. then I have to re-press the route button to
return to the router. I guess, the router exits routing mode by double-clicking the same place.
is there an option to avoid this feature? Thank you for taking the time to read.
