Hello!
Thanks to everybody for your replies, and really sorry for the empty project.
Idea:
If you can route from pin 3, but not from pin 1, then maybe it is because pin 1 is from a power supply net, and you may have set the netclass to sligtly different values for that net.
I can route from pin 3, to the left only. It should work whatever path I first choose. So I reopen the file and try from all the pins:
Pin 1 and 3, see above
Pin 5: works both ways, between 4 and 6 an also 6 and 8
Pin 7: doesn’t route if I want to go between the pins above. I’m aware that the trace from pin 10 is in the way, but hey, it’s configured in “shove” mode and should push the existing track if necessary. Anyway, pin7 doesn’t route between pins 6 and 8 either.
I found the: “(version 4)” string in the kicad_pcb file a bit weird.
I installed the latest nightly build (at least the latest yesterday), which was kicad-r12265.f425f49c1-x86_64.exe.
Anyway the problem happened already in the latest stable version which is 5.0.2.
So maybe it’s a bug in the file generator which uses old strings, I don’t know, but what I can tell is that it was installed yesterday with the installer above.
Application: kicad
Version: (6.0.0-rc1-dev-1650-gf425f49c1), release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
RoutingBug.zip (5.3 KB)
Pascal
