Let us supposed there is a mechanical hole (NPTH) placed in a zone area. Obviously, the zone clearance has to be also applied around the hole. And, as we know, increasing it just around the hole is not possible.
So I did a manual temporary workaround as follows:
[1] I drew a circle on a non-copper layer (F.SilkS for example) around the hole with a suitable radius.
[2] I changed the layer of the circle to B.Cu (where my zone is).
[3] I re-filled the zone area.
[4] I deleted the circle.
And I did this as the last step, right before generating the Gerber files of my layout (and ignoring the option of re-filling the zone, being out-of-date).
But, there may be a better way to do it which I am not aware of, yet.
Receiving any comment will be appreciated.
Thank you.
I think you can just edit a new symbol of a npth then assign a new npth footprint to it. Treat it as integrated component. Cos as the last step of changing property of a circle would be a risky issue for the files which would be updated some day.
