I want to know that can i rotate a track 180 degree using pcbnew python.
There is option of tracks.Rotate() though it is asking for arotCentre and angle, I know about angle but what does aarotCentre represent or asks?
Also can I use Set selection to rotate all the tracks to 180 degree at a time.
your response will be highly appreciated.
Thankyou in advance.
arcCentre should be center of rotation. But if you just need to rotate 180 degree thats easy, if it’s x1,y1 to x2,y2 and you want to rotate around x1y1 then the other end should be x2-2*(x2-x1), y2-2*(y2-y1)
