Rotate a piece of layout within a specific degree of rotation
Hi there,
I’m trying to rotate a piece of layout with excetion of the option of 90º degrees like I can in other ECAD tool, example: select the entire layout block write a comand with a especific degree of rotation.
Any one knows if its possible?
The real problem is execute a rotation with other agle except 90º
thank you
You have two options, depending on what you want to do.
You can choose a different rotation step size in the settings, e.g. 15, for repeated rotations:
You can also rotate a single item or a selection by any arbitrary value by selecting the part(s), right-clicking and selecting special tools > move exactly (default shortcut: shift-m). This dialog is shown, giving you a lot of freedom by combining the different options:
thank you, it solves!
