@maui Thanks for the information is helping me a lot.
The manufacturer of GPS / GNSS module made a Design Review Report and i need to insert a matching network between the module and the antenna to 50 ohm.
it can be calculated with PCB calculator?
I am using 4 layers and have not yet made any trace.
2.1.5. RF aspects
For a better antenna operation, insert a matching network between the module and
the antenna.
2.2. PCB Layout review
2.2.1. General placement
Improve the routing of the tracks on the PCB. The differential tracks of USB signal
should be 90 ohm.
2.2.2. RF aspects
The track between the module and antenna should be 50 ohm.
RF specific laminates are better, but expensive and limit PCB suppliers. For a GPS/GNSS module FR4 should work OK. The exotic laminates are for higher frequencies or “professional/military” uses where reducing insertion loss by 0.5dB is worth spending money
