I have been making my own component symbols and those seem to be working OK. I tend to copy something which is similar to what I want and then edit it to make a new component.
I wanted to add this question to an earlier similar discussion but that one is closed to new questions/comments. (Why do we close these discussions if the software is similar?) My software version is shown at the bottom of this.
Anyway I have copied a +12V symbol to make a +18V symbol. I thought it indicated +18V but the netlist connected this to my +12V. When I try to edit my “+18V” symbol, the symbol editor shows some “invisible” “+12V” text which I could not change.
So…with my “damn the torpedoes” attitude (which crashed my keyboard a few days ago) I opened up the “.lib” file in my text editor. The text below is the result after I changed the text in the line which starts with “X” from “+12V” to “+18V”.
+18V
DEF +18V #PWR 0 0 Y Y 1 F P
F0 “#PWR” 0 -150 50 H I C CNN
F1 “+18V” 0 140 30 H V C CNN
F2 “” 0 0 50 H I C CNN
F3 “” 0 0 50 H I C CNN
DRAW
P 2 0 1 0 -30 50 0 100 N
P 2 0 1 0 0 0 0 100 N
P 2 0 1 0 0 100 30 50 N
X +18V 1 0 0 0 U 50 50 1 1 W N
ENDDRAW
This seems to work and pcbnew now is showing the desired connections after reading the netlist. Was text-editing the .lib file a bad idea? And if it is OK; it seems that the software ought to be able to do it without too much difficulty?
Thanks. This is my KiCad version report:
Application: kicad
Version: (5.0.2)-1, release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
