In my current project I am using a TF Card “socket” (aka micro SD). After some searching through digikey I decided to use the ubiquitous ebay socket. I like the 4 solder pads for holding it to the board and I think I can actually hand solder the connection pins.
The 3d model will not be accepted as we do not accept third party contributions for legal reasons (only the original owner can change the license of an asset)
The footprint can be contributed but must follow the library convention. At this point in time an additional requirement is that any contribution must be made with a recent nightly build and must use the new features if applicable (example is the use of true keepout areas instead of relying on a workaround)
Thanks for all the input. I understand the licensing for 3D files. Makes perfect sense. I will make the footprint available after I’ve received my boards and verify the functionality as I’ve tweaked the footprint to make it a little easier to hand solder.
The “official” libraries also have some footprints optimised for handsoldering, which have the postfix “_Handsoldering” and also have the keyword “Handsoldering” in the footprint.
