figured that
it says 1 unconnected but i cant see any white lines anywhere, can kicad zoom in to where it thinks this unconnected is so i can fix it?
figured that
This thread may help
I’m unsure how KiCad DRC manages a trace that passes ‘clean over’ a pad (ie no trace corner inside pad), given your creation method, you might have one of those ?
i found it… between 2 pads on a big ic
turend out that on schematic i have by mistake placed the same wire label on the pad next to the right one
deleted the label and all was good again, but i only found out as i turned off all layers
I have fine adjusted most of the tracks on the top layer
is it possible to do octogon shaped pads in kicad? i have googled a bit but nothing comes to mind
No. In kicad v5 you will be able to use rounded rectangles or complex shapes via polygon pads.
have a strange issue
as you can see at one pad the copper flood does connect to the pad but not the other, i have checked that both pad settings are set to solid
what could be wrong here, i’m open to user mistake but i cant figure what
copper zones have an offset to the edge cuts layer.
Is there a specific reason you are using edge cuts drawings for oval “drills” instead of defining them as oval in the pad settings?
ahh will try and see if i can fix that
i used edge cut as a milling option that these holes need
EDIT: Fixed, thanks once again. It’s getting close where i should mention Kicad forum somewhere on the copper
one of the last things before i can go and fine polish every small track
i have a track that just ends blind on the board and i have routed it from the blind end
are there a way i can tell kicad what net name a track belongs to? or do i have to rip the tracks and route from the pad it connects to?
a pic says more than 1000 words: https://imgur.com/a/q6NAP
I don’t think there is a way to set the net name directly from the GUI, but a couple of possibilities;
Turn off DRC, connect the track to the pad you want. Then re-import the netlist. I find this causes tracks to be reassociated with the pads they are overlapping on the board, even if they weren’t drawn that way originally.
(For advanced users) Close the pcb, make a backup! Edit the kicad_pcb file in a text editor (but not a word processor). Find the segments with no net name and manually add the net name to them, e.g.
(segment (start 71.8656 80.9263) (end 83.9067 92.9674) (width 0.25) (layer B.Cu) (net 35))
(segment (start 85.2187 94.2794) (end 83.9067 92.9674) (width 0.25) (layer F.Cu) (net 35))
(segment (start 85.2187 95.27) (end 85.2187 94.2794) (width 0.25) (layer F.Cu) (net 35))
There is a table near the start of the kicad_pcb file giving the number for each net name.
In v5 the net can be set in track’s Properties dialog. I don’t know about v4, if it’s not there, maybe you have to try what bobc suggested.
Trying this in 5.0.0-rc2-dev-44-gde6b32d23 shows a few rules
Not sure if there is a way to disable that last feature ?
Applying those rules, it depends on if your pad is named, and if it needs a new net name.
Best idea is to connect a net name to the pin, in the schematic, and it should automatically name the trace polygon (using the first rule).
i use 4.0.7 and yes there are only one “simple” way to do it… connect from the pad on the chip and work from there
next “problem”:
i have spent a lot of time to make the edgecut lines connect, but i have found out that the userport and cassette ports are not quite right
can i move things in blocks in a precise way? i move one outer edge and the 2 arcs as a single block say 0.6mm?
Looks like group select, and move-exact is what you need.
Select items all move grouped, & non selected item stay, so you will need to add/subtract the gaps to close the polygon.
yep… i was just about to say that i selected the parts individual and used the move exact command
another odd one…
in 3d view the pads for the userport and cassette are grey, but you can just get a glimpse that they are yellow under it
arround the lower edge and to the left plus a few spots i have added a zone that removes the solder mask
and i did the same on the pads in the upper left of the board but they still come out grey for some reason
pic from 3d view: https://imgur.com/a/7OZAG
what could it be?
Solder Paste …
and some chars
i allready had a zone for the F.mask layer so i just copied the zone to the F.paste layer and then i got this: https://imgur.com/a/NJUag
Are you sure you want solderpaste there? These look like edge connectors. Normally you will not want to solder something to them.
nope and like the noob/idiot/failure i’m i cant figure to remove it
trying thou
