Repeated PCB footprint
When designing a circuit, I modified the SCH. After updating it to the PCB, multiple duplicate footprints appeared with the same position number. The update did not delete or merge them. What is the reason?
I think it is due to the first checkbox you ticked. You probably never need that ticked, there are only some very special edge cases for when you want that.
I tested it, and it didn’t work。
Did you try this ?
Removing footprint fields does not remove unused footprints. And the Delete footprints with no symbols checkbox is on.
So I am a bit puzzled why this Error: Multiple footprints found for … occurs.
I do agree with Mineotopia. the Re-link footprints to schematic symbols based … option should always be off, and only be used in some specific but rare scenario’s.
a little bit of testing later…
Locked footprints are not removed, but they do show up in the Update PCB from Schematic dialog:
(Screenshot from KiCad V8.0.9, so slightly different options).
But I don’t see the Locked Item Shadow. This could be turned off. Are there errors for Cannot remove unused footprints in the update dialog?
A quick fix would be to just delete all footprints on the PCB and then do a clean Update PCB from Schematic [F8], but that would not explain how this happened in the first place.
Ah Yes . . . “Delete footprints with no symbols” is what I had in mind, but it’s already selected as you said.
You can find more information about linkage between footprints and symbols here: Update PCB from Schematic's match methods - #2 by eelik. But I can’t see right away what’s your situation, so the technical explanation isn’t necessarily very helpful for you, either.
Can you share the project in its current state?
