So finally a PCB is finished, but the order/numbering of the components on the PCB does not "look “good”; I want the numbering running in order like R1, R2, R3, R4, in rows/columns etc in a decided pattern.
In eagle I run a ULP (user language program) to make this thing, simple and always with good results. When I run the Tools/Geographical Annotate in KiCad (which I think should do about the same) it messes all up (=PCB is all out of order/ratnest light upp everywhere) after I run Tools/Update Schematics From PCB . What am I doing wrong? Is there instructions somewhere how to make this work, without needing to start from scratch with the routing of the PCB?
all steps in pcb-editor:
1.) Update pcb from schematic (to get both files consistent)
2.) Tools/Geographical Annotate
3.) feed back the new reference-annotation to the schematic:
Tools–>Update schematic from pcb.
There is a checkbox named: re-link footprints to schematic symbols based on their refrence designators.
As you have deliberatly changed the reference-designators: uncheck the checkbox.
The assignment will take place on the basis of the internal UUID-numbers every symbol+footprint has got
4.) to be sure I repeat step 1) to get the consistency back/forth between schematic/pcb. This is maybe not necessary.
5.) save both files
I agree with that, so I had a look at gitlab. There already is an issue very similar to it:
If the PCB has been changed for example by adding footprints to it, then there is no match between any (also manually added?) schematic symbol (yet), then you use this to connect schematic symbols to PCB footprints. It is the (only?) way to fix mis matches between the schematic and the PCB, as the UUID’s that KiCad normally uses for this are not user editable. I have used this occasionaly to “fix” things. It also makes it symmetric because PCB Editor / Tools / Update PCB from Schematic [F8] has the equivalent checkbox.
