In the board editor, some net names follows this format:
J1-pad1
I want to rename these nets to specify their function. However, in the pad properties window it seems that I’m not allowed to use spaces when I create a new name in the drop down menu of net names.
Is there a fix/workaround for this? Or am I simply using the wrong method?
I am not at all surprised at this restriction. Spaces in names cause problems in many areas. Just do what everyone else does and use an underscore e.g. ‘NET_NAME’ or as @anon75181398 suggests, a label.
I had not tried using net names which included a space. But here I have experimentally changed a global schematic net label to “Space Name”; it appears to get through to the layout. I do not know if any errors would be forthcoming.
