If I create a multi-part component is it possible to rename UNIT A UNIT B etc to more descriptive names, or add descriptions to the units?
I have a 244 pin component I would like to separate into blocks e.g. “Power” “GPIO” etc. I can’t seem to find anything relevant by searching, maybe Google-fu is broken.
This is a interesting concept. Even when using BGA ICs or module (like beagle bone).
If you don’t find any solution, I propose to request this feature to developers.
While you can’t put it in the name, you can certainly have it as text in the symbol graphic (which can be different in the different units). That way you don’t have to try to identify the unit’s function by staring at the pin names and guessing.
