I’m working on a hiearchical schematic using v8.0.5. I orginally named a schematic sheet “Interface” but now I want to change it to “Host_Interface”. I looked in the help and I can’t seem to find how to do it.
How change a subsheet name from within eeschema?
Am I really stuck with closing KiCAD and hand editing the root file?
Thank you for your time,
JasonG
P.S. I asked a chat bot how to do it and it gave me directions to use non-existent menu and dialog box choices. I then said, I’m using version 8 and it said that things had changed. Then it told me to use different non-existent menu and dialog box choices.
Thank you bertrand_meneroud. That worked. I didn’t think that doing that would actually rename the file.
After you change the name, it pops up a dialog asking if you want it to create a new file with the contents of the old sheet. I clicked yes and the new file appeared. I liked that it didn’t delete the old file although in this particular case I will.
