I’m currently on a pcb for a current sensing application. There will be quite a “high” → Max 22A.
Now, i’m not sure how to explain this but the picture should make it more clear. As you can see the connection directly at pins is very narrow. Can I somehow make this as a close polygon plane? Or how would you go about this?
Thanks in advance
