The “Derive from symbol” property needs to be set in the “New Symbol” pop-up menu.
To do this:
Select your symbol “TH”,
Highlight the library in which you placed “TH”
Select “New Symbol” icon
Edit or delete anything in the “Derived from existing symbol” box.
The “Derive from Symbol” line in the “Library Symbol Properties” may only be used to change a symbol from the available selection in the drop-down list shown when clicking the right hand arrow.
Where “derive from existing symbol” is already empty.
Are you sure your suggestion works as you described? can you show me a screenshot how it looks on you?
