BZR6608, Win7 64bit
Scenario:
Outside of KiCAD (File browser) I have copied some footprint files (.kicad_mod) into a pretty folder that is already known to the running instance of KiCAD.
Question:
How do I get KiCAD to check this folder for changes?
any button somewhere?
For symbols this is pretty easy - just open the Preferences>Component Libraries dialog and exit it with [OK].
Any external changes will be applied to the running instance of KiCAD.
This is not working with footprints, i.e. opening the Library Manager doesnât do this kind of reloading of whatâs in the files/folders.
[EDIT]
found a workaroundâŚ
Open the >Preferences>Library Manager and then append the folder (footprint library) with the wizard under another name (simple add a â2â to the name for example).
Close the dialog.
Check the original library with the browser and see the new footprints have being loaded.
Reopen the library manager and remove the 2nd instance of the library.
