I’ve just noticed that release candidate 9.0.0-rc1 has been tagged in the Source code mirror. What does this mean from a user’s perspective, and should we get excited yet?
There will be an announcement once installable packages are widely available.
Don’t expect RC1 to jump straight to release, the bug fixes have been a steady stream. RC1 means time for more eyes to look for and report bugs.
The release plan hasn’t changed – end of Jan / early Feb 2025.
One key change is that in Windows OS, RC1 installs as V9.0, not V8.99 and this leads to a new icon and directory tree in Documents/KiCad.
We have about a month to test non-critical projects in RCs and catch those bugs before release.
Some tips for this on Windows:
- Start off with the full build, not Lite - you need those libraries in the new directories.
- Make sure the libraries are checked in the installer dialog
- Copy your test project(s) to documents/KiCad/V9.0/projects
- Open a project from the new directory to avoid messing older version projects
I missed (2) and had all kinds of strange warnings and a hang
I would like to do some testing and maybe help in reporting bugs, If I stumble across some.
However, I do not want to break my “produtive” 8.0.7 Kicad. Is it “safe” to use the installable nightly packages such as the current one in
(https://downloads.kicad.org/kicad/windows/explore/nightlies/download/kicad-nightly-9.0.0.rc1.18.gc587788430-x86_64.exe) in the sense of “does not share settings” with existing Kicad installations?
Thanks!
The rc1 release announcement hasn’t been made yet, but it should create a new settings directory separate from your v8 settings.
In terms of using it, please make a backup of your project files so if there are any critical bugs you don’t lose your work.
It does not share settings, but any designs or personal libraries that you edit in V9 will no longer open in 8.0.7
On Windows, I have 6,7,8 and 9RC installed in parallel and independent of each others settings.
Always copy your job from olderversion/projects to newversion/projects and open in the new directory to avoid converting the old job.
