Regarding writing the text on pcb
Hie everyone,
I am designing a PCB and i want to write some extra text on pcb which is not present in schematic.
So,
How can i write text on PCB and by using which layer should i write text ?
for example : F.silk, F.adhes etc…
f.silk is good candidate indeed
thankyou very much dude. So, i cannot use F.adhes right..!
Its purpose is for assembly, you may need to fix some components with glue before reflow and this layer shows where to dispense it.
thankyou so much for your valuble information dude. Now i got complete idea of all the layers.
Regards,
Anirudh THABJUL
Be careful, also, when you print your gerbers. There is a dialog box that gives you the opportunity to choose what gets printed in the gerber files. Be sure to check which items you want to print in the gerbers.
I made the mistake of not un-checking some of the items to prevent component values or labels. This caused the component labels to conflict with some other f.silks writing that I had wanted to print there and not the component labels.
Be sure to examine your gerbers very carefully using the gerb view tool.
dwight
thankyou Andy for taking time to clear my doubt.
Thanks a lot..!
Regards
Anirudh THABJUL
Ok..! i will examine properly my gerber files while sending to manufacturers.
thankyou for your valuable suggestion :smile:
Regards
Anirudh THABJUL
