Refill zones via CLI - or - Custom DRC rule for out-of-date zones
Hi!
My team is working on automating our export process, and one concern came up which I haven’t found a way to automate around.
When zone fills are out of date, the GUI gerber export button will warn you and prompt you to re-fill (or decline). When exporting gerbers via KiCad CLI, the user is not left any similar notice or warning.
I have looked through the custom DRC rules syntax and haven’t found a fitting set of rules which would fail given out-of-date zones on a layout. Similarly, I don’t believe there is currently an option in the CLI to re-fill the zones prior to exporting.
Is anyone aware of any workarounds for this? We would like to prevent our CI from allowing exports with accidentally outdated zones; either by failing the DRC test stage, or by re-filling the zones and writing to the kicad_pcb. We could then still fail the job with a git diff (or similar), instructing the author that the state at which they committed the layout has outdated zones.
Thanks!
kicad-cli is a relatively new utility, and some functionality is still “missing”. There is an open issue for this on gitlab, but Re-calculating internal zone geometry is apparently not on that list (yet).
A little test:
paul@cezanne:~$ kicad-cli pcb export gerbers
input: 1 argument(s) expected. 0 provided.
Usage: gerbers [--help] [--output OUTPUT_FILE] [--layers LAYER_LIST] [--drawing-sheet SHEET_PATH] [--define-var KEY=VALUE] [--exclude-refdes] [--exclude-value] [--include-border-title] [--no-x2] [--no-netlist] [--subtract-soldermask] [--disable-aperture-macros] [--use-drill-file-origin] [--precision PRECISION] [--no-protel-ext] [--common-layers COMMON_LAYER_LIST] [--board-plot-params] INPUT_FILE
Plot multiple Gerbers for a PCB, including the ability to use stored board plot settings
Positional arguments:
  INPUT_FILE                     Input file
Optional arguments:
  -h, --help                     Shows help message and exits
  -o, --output                   Output file [nargs=0..1] [default: ""]
  -l, --layers                   Comma separated list of untranslated layer names to include such as F.Cu,B.Cu [nargs=0..1] [default: ""]
  --drawing-sheet                Path to drawing sheet, this overrides any existing project defined sheet when used [nargs=0..1] [default: ""]
  -D, --define-var               Overrides or adds project variables, can be used multiple times to declare multiple variables.
                                 Use in the format of '--define-var key=value' or '-D key=value' [nargs=0..1] [default: {}]
  --erd, --exclude-refdes        Exclude the reference designator text
  --ev, --exclude-value          Exclude the value text
  --ibt, --include-border-title  Include the border and title block
  --no-x2                        Do not use the extended X2 format
  --no-netlist                   Do not generate netlist attributes
  --subtract-soldermask          Subtract soldermask from silkscreen
  --disable-aperture-macros      Disable aperture macros
  --use-drill-file-origin        Use drill/place file origin
  --precision                    Precision of Gerber coordinates, valid options: 5 or 6 [nargs=0..1] [default: 6]
  --no-protel-ext                Use KiCad Gerber file extension
  --cl, --common-layers          Layers to include on each plot, comma separated list of untranslated layer names to include such as F.Cu,B.Cu [nargs=0..1] [default: ""]
  --board-plot-params            Use the Gerber plot settings already configured in the board file
I am not too familar with kicad-cli. Is there anything you can do with: --board-plot-params? I guess it makes you dependent on whatever the status of that checkbox is in the project.
It is an important feature for automated output generation, and thus worth a feature request.
Hey Paul,
Board plot params is one avenue I didn’t look into too deeply. I don’t think there is a board project setting which would mandate re-fill upon export, but I’ll take a deeper look. Thanks for the suggestion. If this does not yield what we’re looking for I’ll certainly put in a feature request, I think this would be a great feature to have for any teams utilizing the CLI.
Thanks again, will let you know.
Yea unfortunately the refill system is still tied to the GUI so it hasn’t been freed from it’s entanglement to enable it for cli.
