References gone invisible
At some point I have moved the reference outside the edges of the board and made them invisible. I then cannot see them, or even select the right area… If I select the component and Edit Properties (I’m on the most recent nightly at the moment, but had the same problem with the last stable) and then press the button to edit the reference it claims it’s visible and the entries are identical for references on the other side which are visible. I’ve re-read the netlist in several time… Tried looking in Preferences… Even look at the text in save pcb file…
Any clues?
Found it, had switched off Text Front in the Render tab. Idiot
