Reference Designator Number Disappearing
I’m having a problem with the reference designator numbers reverting to ? randomly. I worked on a schematic yesterday and set the reference designator numbers on the components and saved the file. This morning when I opened the schematic a number of the components reference designator numbers had been changed back to ?. Also if I move a block of components by selecting them to move them around on the schematic the reference designator numbers get set to ?. Any clue as to why this is happening?
Version: 8.0.8-8.0.8-0~ubuntu24.04.1, release build
wxWidgets 3.2.4
FreeType 2.13.2
HarfBuzz 8.3.0
FontConfig 2.15.0
libcurl/8.5.0 OpenSSL/3.0.13 zlib/1.3 brotli/1.1.0 zstd/1.5.5 libidn2/2.3.7 libpsl/0.21.2 (+libidn2/2.3.7) libssh/0.10.6/openssl/zlib nghttp2/1.59.0 librtmp/2.3 OpenLDAP/2.6.7
Platform: Linux Mint 22.1, 64 bit, Little endian, wxGTK, X11, cinnamon, x11
OpenGL: NVIDIA Corporation, Quadro P2200/PCIe/SSE2, 4.6.0 NVIDIA 535.183.01
Date: Jan 14 2025 02:26:31
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.6.3
Curl: 8.5.0
ngspice: 43
Compiler: GCC 13.3.0 with C++ ABI 1018
Welcome to the forum:
First: Please refer to either symbols (on schematics) or footprints (on pcbs). Those are the standard KiCad nomenclature. “Components” is ambiguous in the KiCad context.
Secondly, were the Ref Designations assigned automatically or did you assign them manually? Is it possible that you had duplicates or did something else to assign them improperly?
Tools>annotate schematic should assign them. But…I understand wanting to do it manually. I often prefer Q1 to be main switching transistor, or I want resistors in a divider string to have sequential reference designations. I then do some swapping of the Ref designations but…
I have not experienced your particular issue.
Sorry about my incorrect wording. It’s the symbols on the schematic that are the problem. I am assigning the Ref Designators manually. I’m creating a schematic of the PCB out of my soldering station and I want to use the same Ref Designators that exist on the board so I turned off automatic annotation. I’m not sure what I could have done improperly to assign the Ref Designators. I double click on the symbol and change the designator and save it. It takes but then reverts back to ? at some point for some reason.
I think we will probably need someone more knowledgeable to weigh in. I did a bit of experimentation in the attached, and found no surprises.
Why don’t you play with this file a bit and see what happens? Document your moves as I did. That might tell us something (??)
If you re-post it, please change the filename.
Test 02-11-2025a.kicad_sch (58.1 KB)
I am using:
Application: KiCad x64 on x64
Version: 8.0.8-182-g34ce2b4ea0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.0.1
FontConfig 2.15.0
libcurl/8.10.1-DEV Schannel zlib/1.3.1
OpenGL: Intel, Intel(R) Iris(R) Xe Graphics, 4.6.0 - Build 31.0.101.5186
Date: Feb 5 2025 04:21:17
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.10.1-DEV
ngspice: 44
I figured out when it’s doing it but not why. If I double click on the symbol and change the Ref Designator in the dialog box that pops up then save the schematic and close it the change sticks when I reopen the schematic.
If I double click on just the Ref Designator and change it in the dialog box that pops up then save the schematic and close it the change sticks when I reopen the schematic.
If I click on the symbol once to bring up the properties on the left side of the screen under “Fields” and change the Ref Designator there and then save the schematic and close it the change sticks when I reopen the schematic.
If I click on the just the Ref Designator once to bring up the properties on the left side of the screen under “Fields” and change the Ref Designator there and then save the schematic and close it the change does not stick when I reopen the schematic and the Ref Designator is back to what it was prior to changing it.
It works for me. After editing it in the properties panel you have to deselect the refdes by clicking somewhere else then you will see the refdes change on the schematic and the modification will take.
But if you change the property you would expect it to be changed and saved when you save, right? Sounds like a bug…
First of all, I think you mean “context menu click”?? (Usually right mouse button, but not in my setup.)
So RMB click on Ref Des
Properties
Edit Ref Des
OK
Save schematic
Close schematic and KiCad
Re-Open Schematic.
For me, the change sticks. I wonder whether there could be a difference between Win11 and your Ubuntu?
I agree.
I was hitting the Enter key after typing in the new Ref Designator. It has always taken the change but it’s when I save the schematic, close it and then open it the change is not there. This time I tried clicking on an open space in the schematic to deselect the refdes and then saving the schematic. I open the schematic and the change does not take.
Please re-read your post carefully. Did you write what you intended?
Also maybe important: Is “Automatically annotate symbols” selected or de-selected?
No, not context menu click. I’m talking about the place on the left side of the screen that’s displaying the properties of the item when you left click on it. It’s labeled “Field” and under that there’s “Text Properties”, that’s where I’m making the changes to the refdes.
Maybe it would be better if I said the change didn’t survive the save and reopen of the schematic.
Auto annotation is turned off.
I THINK I HAVE DUPLICATED THE ISSUE.
I don’t think I had ever used that particular menu button before. The below is a .gif:
BobZ Feb 11b
I can confirm this is a bug. It looks like the Refdes-change takes place, but it’s not saved.
Happens also with the upcoming version kicad v9. I will open a gitlab issue, maybe this get’s corrected before v9 is officially released.
@BobZ : I have copied your nice animation into the issue, hope you don’t send the lawyers.
That works for me too. When I tried to exit the schematic it said there were unsaved changes, but I didn’t actually save to see if the change took. I’m actually on an earlier version than you, 8.0.6. My distro hasn’t caught up.
Good, so I’m not as crazy as I was beginning to think. :sweat_smile:
