I’m getting different errors, but I’m going to try and figure those out as well! I’ll update the forum if I find some tips/techniques for these problems. Thank you!
Try running the kicad.exe found in C:\msys32\mingw64\bin (or similar location).
OH! What is the difference between the two executables?
kicad.exe will be copied to C:\msys32\mingw64\bin if you run “make install” (which builds if required and installs to the msys filetree). If you are building to debug, you may want use a different make command.
