Kicad 5.99 came with more option on the 3d viewer display option, especially on the raytracing menu. But I can’t get the right setting to preproduce the same “color result” as the Kicad 5 (stable) does, it’s either too bright or too dark. I suspect it’s from the lighting config (and solder mask opacity) because I pretty much checked the same setting on the all other options.
Here’s the side by side render between Kicad 5.1 (left) and 5.99 (right)
I like the 5.1 color result, but 5.99 is having a right result for castellated hole. Can anyone tell me which parameter needed to be tweaked? or better by share your current config.
Thanks.
