Hi experts,
I am seeing some ratsnest connection problems in pcbnew with standard diodes.
To illustrate, I have created a very simple circuit in EEschema using two standard diodes, a Zener diode, and an LED as follows:
Loading the netlist in pcbnew shows the following ratsnest:
As one can see, whereas the Zener diode (D3) and the LED (D4) anode and cathode terminals are connected correctly as drawn in the schematic, the anode and cathode connections of the standard diodes (D1 & D2) are reversed in the ratsnest though.
I can hardly believe that this can be a bug but probably I am simply confusing something here.
Could someone help me in understanding where my mistake is, please?
For your reference, I have attached the “.sch”, “.kicad_pcb” and “.net” files here - just in case they are required.
210101 Test.sch (4.2 KB)
210101 Test.net (6.9 KB)
210101 Test.kicad_pcb (24.8 KB)
I am using Kicad Version (5.8.1) -1 on Windows 10 Pro 64-bit.
Application: KiCad
Version: (5.1.8)-1, release build
wxWidgets 3.0.5
libcurl/7.71.0 OpenSSL/1.1.1g (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.41.0
wxWidgets: 3.0.5 (wchar_t,wx containers,compatible with 2.8)
Boost: 1.73.0
Curl: 7.71.0
Compiler: GCC 10.2.0 with C++ ABI 1014
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Looking forward to your advice/comments.
Thanks and best regards
