Ratsnest leads to a trace on the opposite of the board. In the below screenshot the annotated ratsnest leads to the opposite of the board. While this is technically correct, when I turn off the bottom layer to aid in visualization it leaves the ratsnest line hanging in space. Is there a way to have the ratsnest stay on one side (selectable would be nice)?
The ratsnest kicad places is attached to the closest two parts, either a footprint or the end/direction change of a track. I was wondering how the “stay on one side & selectable” could be applied. That is all.
My initial thought was that there may be an option already in the program. I couldn’t find such in the documentation of going through the program.
But to answer your question: A rule that stated the ratsnest would go to a location on the same side if possible then go to the opposite side. Could this cause other issues? I don’t know, I haven’t thought that far.
Hey there! I came looking for this thread after seeing your post in the other one!
While the Net Display Options probably does what OP asked, I noticed a seemingly strange behavior. KiCad will continue showing you the ratsnest connections to the other side of the board while drawing a trace, regardless of that setting.
At first, I thought this didn’t make sense. However, I guess the idea is that when you draw a trace, it would provide some guidance on where you could drop a via.
