all of a sudden the rastnet stopped working
case is i have a schematic and i have used the drag command to check that all components are connected
one component is a resistor that is connected to vcc at one end and to a reset line at the other end, simple enough right?
footprint is assigned and i create the netlist
and i read the netlist in pcbnew, but the same resistor is now not connected to anything, not connected to vcc or the reset line
what could it be?
